Nov 29, 2006 #1 O oomywayoo Newbie level 4 Joined Nov 29, 2006 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,305 Hi I have built digital correction logic in matlab . How to send the H-spice result into Matlab for calculate SNDR? THANKS
Nov 30, 2006 #2 P pfd001 Advanced Member level 1 Joined Jul 23, 2005 Messages 409 Helped 45 Reputation 90 Reaction score 10 Trophy points 1,298 Activity points 3,214 the hspice simulation results can be saved as a file and then loaded into the matlab
Nov 30, 2006 #3 gunpla Junior Member level 1 Joined Mar 16, 2006 Messages 15 Helped 3 Reputation 6 Reaction score 3 Trophy points 1,283 Activity points 1,391 after running hspice,you can get output by .lis file if using .print in your simulation file then open .lis and delete you don't want information save you data as .mat in matlab command windows load('-ascii','file name') the file must in your current directory then process the matrix by error cancellation logic good luck! ps. sorry,i got D in English XD
Nov 30, 2006 #4 O oomywayoo Newbie level 4 Joined Nov 29, 2006 Messages 5 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,305 Thank you very much~~!!
Dec 2, 2006 #5 O okguy Full Member level 6 Joined Mar 1, 2002 Messages 360 Helped 15 Reputation 30 Reaction score 9 Trophy points 1,298 Location China Activity points 2,653 Try the hspice command : .lprint It is the logic print out, much more efficient for logic signals, as it only ouput digital 0 and 1.
