Question about different ways of describing MUX in Verilog
nervecell_23
Member level 1
Member level 1
For instance, to implement an registered 2-bits 5:1 MUX:
1) use 'case' statement:
reg [1:0] out;
wire [1:0] i_1, i_2, ... , i_5;
always@(posedge clk)
begin
    case(sel)
        3'b000: out <= i_1;
        3'b001: out <= i_2;
    endcase
end
I wonder whether the following 'array' style implementation would work or not:
wire [1:0] in [0:4];
reg [1:0] out;
assign in[0] = i_1;
assign in[1] = i_2;
assign in[4] = i_5;
begin
    out <= in[sel];
end
Yes, an array works, but will result in out of range and indeterminate results if the sel exceeds the range of the [0:4] index. I'm pretty sure anything outside the range become don't cares, but verify that is the behavior in your synthesis tool.
Regards
