The difference between two stages of the system has to be clear
1. sampling a physical(analog) signal, eg. voice, to a digital form: in this stage, if the the analoge signal bandwidth is B the sampling rate has to be 2B min.(Nyquist rate) after that each sample is represented using a specific number of bits (say k), the bit rate will be (2Bk bps), (as an example, encoding the voice 4 kHz* 2(Nyquist rate)*8kbit/sample=64kbps). this stage absolutly has no relation with the transmission or the transmission technique, eg.ASK, FSK, PSK,......, .the sampling may be for storage not for transmission.
2. the second stage is the transmission, the digital date stored need to be transmitted(2Bk bps in 1, S bps in your question), it has to be represented in a from suitable for the transmission channel(eg. ASK, FSK, PSK,......), the bandwidth depends on the technique, the bandwidth for each is available in text books.
