mamech
Full Member level 3
hello
I am dealing nowadays with a project that needs analog isolation of mains voltage.
I got the following circuit from a schematic of educational kit that uses IC ADE7953 for power metering.
they use attenuation circuit to attenuate the mains voltage to sample it using ADC in the IC.
the problem of this configuration,the mains is connected directly to the IC and also that the ground of IC will be connected to neutral (or even line, in case the user swap the plug) , so this is not good from protection point of view.
it is suggested to use potential transformers to get the mains voltage totally isolated to the metering IC ADE7953.
the problem is that I do not now what are potential transformers. Are they different than normal Ac transformers? and do they exist in miniature package?
I searched the Internet using the name of potential transformers, but it seems that this is not the commercial name of it.
in another post here, I found someone talks about signal transfomer, is it the same as potential transformers??
any recommendations ?
thank you very much
thank you very much
