[PIC] question about ADC module on uC
silverwolfman
Junior Member level 1
MPLAB X16, dsPIC33FJ
Hi guys,
Its my first time tried to use the ADC module and it really gives me some hard time, I've tried to use AN1 & AN2 as the analog input, 12bit accuracy, using scan method and only opened muxA, I saw the value change in ADC1BUF0(its fluctuated because its switching between AN1 and AN2), the device I am using is with DMA, I have 2 questions:
1.what should I do to read out the these two value sperately? I am not quite familiar with the DMA. Can I have some examples how to setup and use the DMA for ADC?
2.another question is, if I have to match the two Analog input to DMA, does that mean the device with DMA is slower? In stead of reading directly from register(ADC1BUF0,ADC1BUF1....in device without DMA) I have to write the value into memory first and then read back?
Thanks ahead.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
/********* Initialize ADC  **************************************/
void InitADC(void){
        TRISB|=0x0001;
        TRISA|=0x0003;
        AD1PCFGL=0xFFF8;         //AN0=external reference, AN1, AN2
        AD1CON1bits.ADON=0;     //turn off the adc
        AD1CON1bits.AD12B=1;    //12bit conversion CH0
    AD1CON1bits.ASAM=1;    //Sampling begins after conversion auto sampling
        AD1CON1bits.SSRC=7;     //Automatic sampling the data
    AD1CSSL=0x0006;    //Sample scan channels AN1& AN2
        AD1CON1bits.FORM=1;     //signed data
    AD1CON2bits.CSCNA=1;    //select scan auto sampling
    AD1CON2bits.SMPI=0x0001;//select 2 conversion after sampling
    AD1CON2bits.VCFG=0; //select reference source
    AD1CON2bits.ALTS=0; //Just use the scan channel
        AD1CON3bits.ADRC=0; //system clock as sampling
    AD1CON3bits.SAMC=0x1;   //sample clock
        AD1CON3bits.ADCS=63;   //ADC clock frequency=100kHz
        AD1CHS0=0x0101;   //scan AN1 and AN2 using MuxA
        AD1CON1bits.ADON=1;   //enable ADC
there are some example of using dsPIC33 ADCs with DMA on Microchip's code examples page
below is code I used with a dsPIC33EP256MU806 adapted from one of microchip's examples
#if defined(__dsPIC33E__)
#include "p33exxxx.h"
#elif defined(__PIC24E__)
#include "p24exxxx.h"
#endif
#include "hardware.h"
#include <libpic30.h>		// for __delay_us FCY must be defined!
#include "adc1.h"
// User Defines
#define NUMSAMP	256
//int BufferA[NUMSAMP] __attribute__((space(dma)));
//int BufferB[NUMSAMP] __attribute__((space(dma)));
#ifdef _HAS_DMA_
__eds__ int BufferA[NUMSAMP] __attribute__((eds,space(dma)));
__eds__ int BufferB[NUMSAMP] __attribute__((eds,space(dma)));
#else
 int BufferA[NUMSAMP] __attribute__((space(xmemory)));
int BufferB[NUMSAMP] __attribute__((space(xmemory)));
#endif
void ProcessADCSamples(__eds__ int * AdcBuffer);
//Functions:
//initAdc1() is used to configure A/D to convert ANchannel in 12bit mode
//at 500Ksamples/second throughput rate. ADC clock is configured at Tad=150
//  assuming an FCY of 60MIPS
void initAdc1(int ANchannel)
		AD1CON1bits.FORM   = 0;		// Data Output Format: integer
		AD1CON1bits.SSRC   = 7;		// Interan Counter (SAMC) ends sampling and starts convertion
		AD1CON1bits.ASAM   = 0;		// ADC Sample Control: Sampling begins immediately after conversion
		AD1CON1bits.AD12B  = 1;		// 12-bit ADC operation
		AD1CON2bits.CHPS  = 0;		// Converts CH0
		AD1CON3bits.ADRC=0;			// ADC Clock is derived from Systems Clock
		AD1CON3bits.SAMC=2; 		// Auto Sample Time = 0*Tad
		AD1CON3bits.ADCS=5;		    // 12 bit ADC Conversion Clock Tad=Tcy*(ADCS+1)= (1/60M)*4 = 150nSec approx
									// ADC Conversion Time for 10-bit Tc=12*Tad =  900ns (1.1MHz)
									// ADC Conversion Time for 12-bit Tc=14*Tad =  2000ns (500Ksamples/sec)
		AD1CON1bits.ADDMABM = 1; 	// DMA buffers are built in conversion order mode
		AD1CON2bits.SMPI    = 0;	// SMPI must be 0
		AD1CON4bits.ADDMAEN  = 1;		// Converts in ADC1BUF0
  		//AD1CHS0/AD1CHS123: A/D Input Select Register
	    AD1CHS0bits.CH0SA=ANchannel;		// MUXA +ve input selection (AIN0) for CH0 AN24 RE0
		AD1CHS0bits.CH0NA=0;		// MUXA -ve input selection (Vref-) for CH0
	    //AD1CHS123bits.CH123SA=0;	// MUXA +ve input selection (AIN0) for CH1
		//AD1CHS123bits.CH123NA=0;	// MUXA -ve input selection (Vref-) for CH1
        IFS0bits.AD1IF = 0;			// Clear the A/D interrupt flag bit
        IEC0bits.AD1IE = 0;			// Do Not Enable A/D interrupt
        AD1CON1bits.ADON = 1;		// Turn on the A/D converter
        __delay_us(20);			// Delay for 20uS to allow ADC to settle (25nS * 0x320 = 20uS)
        AD1CON1bits.ASAM = 1;		// Sampling begins immediately after last conversion. SAMP bit is auto-set
// DMA0 configuration
// Direction: Read from peripheral address 0-x300 (ADC1BUF0) and write to DMA RAM
// AMODE: Register indirect with post increment
// MODE: Continuous, Ping-Pong Mode
// IRQ: ADC Interrupt
// ADC stores results stored alternatively between DMA_BASE[0]/DMA_BASE[16] on every 16th DMA request
void initDma0(void)
	DMA0CONbits.AMODE = 0;			// Configure DMA for Register indirect with post increment
	DMA0CONbits.MODE  = 2;			// Configure DMA for Continuous Ping-Pong mode
	DMA0PAD=(int)&ADC1BUF0;
	DMA0CNT=(NUMSAMP-1);
	DMA0REQ=13;
	#ifdef _HAS_DMA_
	DMA0STAL = __builtin_dmaoffset(&BufferA);
	DMA0STAH = __builtin_dmapage(&BufferA);
	DMA0STBL = __builtin_dmaoffset(&BufferB);
	DMA0STBH = __builtin_dmapage(&BufferB);
	#else
	DMA0STAL = (unsigned int)&BufferA;
	DMA0STAH = (unsigned int)&BufferA;
	DMA0STBL = (unsigned int)&BufferB;
	DMA0STBH = (unsigned int)&BufferB;
	#endif
	IFS0bits.DMA0IF = 0;			//Clear the DMA interrupt flag bit
    IEC0bits.DMA0IE = 1;			//Set the DMA interrupt enable bit
	DMA0CONbits.CHEN=1;
_DMA0Interrupt(): ISR name is chosen from the device linker script.
unsigned int DmaBuffer = 0;
void __attribute__((interrupt, auto_psv)) _DMA0Interrupt(void)
		if(DmaBuffer == 0)
			ProcessADCSamples(BufferA);
		else
			ProcessADCSamples(BufferB);
		DmaBuffer ^= 1;
static int count=0;
	if(count++ > 100) {LED1=!LED1; count=0; }
//		__builtin_btg((unsigned int *)&LATA, 6); // Toggle RA6
        IFS0bits.DMA0IF = 0;				 	 //Clear the DMA0 Interrupt Flag
int ADCdata;
	/* Do something with ADC Samples */
ADCdata=AdcBuffer[0];
