reyge
Member level 4
ba033 3.3 volt regulator
Hello!
I just bought two BA033 to supply voltage to an IC. Unfortunately, the one bought for me was the TO252-3 package which has very small pins knowing that i am going to put it first in a breadboard. So, I had to solder wires for the 3 pins(not my best skill but see to it that the wires were shorted with the pins by using a multimeter). When I was already testing the regulator, I do not get the 3.3 volt output! I varied my input from 6 to 8 volts but the output is just a voltage slightly lower than the input. I tried the other BA033 and still got the same result. What could possibly be wrong with what I have done? Are there special considerations in handling this regulator?
I could really use some help. Thanks! Attached is the datasheet I researched from the internet
Hello!
