so would I need a fan or could that run enclosed in the box just the same with only a heat sink.
I looked on Google looking for spec's on the Detex Class-D amplifier but I could not find any. Instead I found a Detex website that has lettering that I have never seen before.
Amount of power output with the amount of distortion at various audio frequencies, frequency response and signal to noise ratio would be needed.
Without spec's then it might sound horrible or overheat then have meltdown.SO in other words dont build this amp?
Elliot Sound Products, Projects. Amplabs.com.Can you recommend me to one that I can build, I would love if it has a pcb also.
But only for a moment unless a fan and a huge heatsink are used..
If you have a small speaker that does not produce deep low frequencies well then you can add a "bass boost circuit" that increases the gain at deep low frequencies then the speaker produces them better.I am wondering if I build a bass amp if it would be a good thing to use a bass boost circuit or it actually does the same thing as a volume control, or its a case I can add both because they perform different tasks.
