HI DEAR,
FM broadcasting is a broadcast technology invented by Edwin Howard Armstrong that uses frequency modulation (FM) to provide high-fidelity sound over broadcast radio.
Random noise has a 'triangular' spectral distribution in an FM system, with the effect that noise occurs predominantly at the highest frequencies within the baseband. This can be offset, to a limited extent, by boosting the high frequencies before transmission and reducing them by a corresponding amount in the receiver. Reducing the high frequencies in the receiver also reduces the high-frequency noise. These processes of boosting and then reducing certain frequencies are known as pre-emphasis and de-emphasis respectively.
The amount of pre-emphasis and de-emphasis used is defined by the time constant of a simple RC filter circuit. In most of the world a 50 µs time constant is used. In North America, 75 µs is used. This applies to both mono and stereo transmissions and to baseband audio (not the subcarriers).
The amount of pre-emphasis that can be applied is limited by the fact that many forms of contemporary music contain more high-frequency energy than the musical styles which prevailed at the birth of FM broadcasting. They cannot be pre-emphasized as much because it would cause excessive deviation of the FM carrier. (Systems more modern than FM broadcasting tend to use either program-dependent variable pre-emphasis; e.g. dbx in the BTSC TV sound system or none at all.)
