Depends on how you're trying to use PFM. In many cases it's just one possible way to modulate duty cycle, and doesn't really have any impact on the state space averaged models.1. PFM mode loop is open loop or close loop?
2. Is it required to do Stability Analysis for PFM loop ? If No Why ?
A DC-DC converter is usually closed-loop, PFM or otherwise (do you mean PWM which is the typical control method?).
Normally you need to do an analysis of the stability of any closed-loop control circuit.
I'm not really sure how else to say it. All duty cycle modulation schemes (fixed frequency pwm, constant off time, constant on time, pfm) boil down to the control of ton and toff, and therefore duty cycle, for the purpose of state space averaging anyways. After that is accounted for, analysis is the same as it would be for any other modulation scheme. For info on state space averaging you should read this classic paper: https://www.ee.bgu.ac.il/~kushnero/temp/guamicuk.pdfPlease explain in terms of stability analysis. That will be helpful .
No system has been actually presented. How can we know if the imagined design is open or closed loop? It's a matter of topology rather than modulation method.
It means you should only expect an answer as specific as your question, and your question is extremely vague.I didn't get your point. "System is not present" means what ?
If you're looking for help doing specific analysis, then you should give a detailed schematic at least.PFM loop consist of: Res div feedback, Max current detect block, Zero current detect block, Comparators along with PowerFets, L & C etc.
Please Consider PFM loop as closed loop. Correct me if I am wrong.
