quadrature encoder programming
vibz86
Newbie level 6
quadrature encoder
Iv made a motor controller circuit for 2 motors & each has a quadrature encoder. The pic im using is pic16f877a. I got no idea regrading how im going to programme the pic to accommodate the encoders.
Herewith I have attached the motor controller programme with the encoder initializations. Please it would be a great help for me if someone can help me out to complete the code. I have to use the encoder inputs, calculate the speed and direction of the motors, check if they are correct and adjust the duty cycle of the motors if they are incorrect. As in not good in ccs or assembly, I prefer doing it in mikroc
#device PIC16F877
void m1(int direction)
if(direction = 1)
PORTC.F4=1;
PORTC.F5=0;
else
PORTC.F4=0;
PORTC.F5=1;
void m2(int direction)
if(direction=1)
PORTC.F6=1;
PORTC.F7=0;
else
PORTC.F6=0;
PORTC.F7=1;
void setup_timer0() //for encoder 1
//should be called after configuring the ports(coresponding tris)
TRISA.F4=1; //encoder signal input bit
OPTION_REG=0x80;
OPTION_REG.T0CS=1; //timer0 counter mode
void setup_timer1()
TRISC.F0=1;//encorder signal input bit
T1CON=0;//configure prescale of timer1
T1CON.TMR1CS=1;//To set RC0 as input source for timer1
T1CON.T1OSCEN=0;//internal oscillator disabled
T1CON.T1SYNC=1;//disable synchronization
T1CON.TMR1ON=1;//start timer1
void main()
PORTC=0;
TRISC=0;
setup_timer0();
setup_timer1();
PWM1_INIT(5000);//Both pwm generators share one pulse width value. So one
//initializing is enough
PWM1_change_duty(80);
pwm2_change_duty(200);
m1(1); //m1 forward
m2(0); //m2 backward
pwm1_start();
pwm2_start();
while(1)
delay_ms(1000);
PORTB=TMR0; //Encorder1 value
PORTD=TMR1L; //Encorder2 value
