Hi,I am trying to design the timing recovery loop in the QAM demodulator.If i have finished the algorithm design of the loop,then how can i verify my design in the matlab/simulink?How can i get the proper input I/Q data and the right output data,which can be used to verify my verilog implementation?
Thanks!
1) generate input I/Q data in MATLAB
2) read this data in simulator (Modelsim, Aldec, etc.)
3) save output data of your design in simulator
4) compare the output data of hdl design and MATLAB model
Aldec and Modelsim also can work with MATLAB directly, but i don't know how
u can use the Random integer generator block in the simulink to generate random pulses for the QAM signal. then u can use the doppler block and the AWGN channel for generating the real QAM modulated signals. Verify ur I/Q outputs using the Discrete-Time Scatter plots.
echo on
K=10;N=2*K;T=100;
a=rand(1,36);
a=sign(a-0.5);
b=reshape(a,9,4);
% Generate the 16QAM points
XXX=2*b,1)+b,2)+j*(2*b,3)+b,4));
XX=XXX';
X=[0 XX 0 conj(XX(9:-1:1))];
xt=zeros(1,101);
for t=0:100
for k=0:N-1
xt(1,t+1)=xt(1,t+1)+1/sqrt(N)*X(k+1)*exp(j*2*pi*k*t/T);
echo off
end
end
echo on
xn=zeros(1,N);
for n=0:N-1
for k=0:N-1
xn(n+1)=xn(n+1)+1/sqrt(N)*X(k+1)*exp(j*2*pi*n*k/N);
echo off
end
end
echo on
pause % press any key to see a plot of x(t)
plot([0:100],abs(xt))
% Check the difference between xn and samples of x(t)
for n=0:N-1
d(n+1)=xt(T/N*n+1)-xn(1+n);
echo off
end
echo on
e=norm(d);
Y=zeros(1,10);
for k=1:9
for n=0:N-1
Y(1,k+1)=Y(1,k+1)+1/sqrt(N)*xn(n+1)*exp(-j*2*pi*k*n/N);
echo off
end
end
echo on
dd=Y(1:10)-X(1:10);
ee=norm(dd);
Hello,
Can anyone plz explain, how this formula works,
What is the idead behind using this fromula to generate 16 QAM.
thankyou.
