PWM using PIC with out CCP module ???
sahu
Advanced Member level 2
Uttar pradesh (INDIA)
how can use PWM using PIC with out CCP module ???
my aim controlling brightness of power led.
When you use CCP, you're using the hardware PWM. So, for PWM without CCP module, use software PWM. One way would be to use a timer. Have the timer interrupt at the end of each period. Depending on the time required, keep output on and off as required.
Check this out:
AN1074 - Software PWM Generation for LED Dimming and RGB Color Applications
Hope this helps.
Tahmid.
Dear Sahu
You have use timer to get the pulse. Something like this one
Here is sample
int i;
int percent;
percent = 52; // % time on
while(1) // loop forever
for (i=0; i>100; i++)
if (i < percent)
ra0 = 1; // turn bit on
else
ra0 = 0; // turn bit off
delay_ms(1); //some sort of delay here, determines freq
This will definately help you.
