Hey there guys,
So I have a new water cooled computer with three very big 12" fans. I want these to be temperature controlled, so I figgured the best way was off the motherboard fan header (since this can be set of the CPU temp).
The problem is that the output off the motherboard is PWM (pulse width modulated) and these big slow RPM (but very high flow) fans make a huge amount of PWM noise at slow fan speeds.
Does anyone know a really nice trick to take PWM signals and turn them back into analog voltage modulated signals.... Besides just using a active low pass filter, run into a simple foltage follower for current gain?
Thanks, much appreciated,
Jonno
