pwm using comparator
Thank you.
Empirically? what do you mean?
I posted in "RF, Microwave, Antennas and Optics" because I want to do a fast PWM, i.e >1MHz.
But if a Moderator could move my post in a proper forum I will appreciate.
I need a PWM able to run with a 5 MHz (at the beginning I m using a 1 MHz signal). The comparator used is a very fast comparator, I guess able to follow a 5 MHz input signal...
I m trying to obtain a signal with a varying duty cycle according to the input voltage level.
