T
treez
SEPIC LED drivers are tough to design with high bandwidth.
Therefore, we make do with a low bandwidth.
However, will the low bandwidth mean that we see repetitive led current overshoot during the OFF-to-ON transition of the PWM dimming operation?
That is, the SEPIC is known for its difficulty when used with high crossover frequency. As such, are there specific problems encountered when PWM dimming a SEPIC converter with the LM3421 LED driver IC (and using a dimming FET in series with the LEDs)
Can we be sure that the voltage on the COMP pin will not rise when the LM3421 is on the OFF time of PWM dimming?......since we don't want the led current to overshoot when the dimming fet is turned back on during PWM dimming cycles.
LM3421 DATASHEET:
https://www.ti.com/lit/ds/symlink/lm3421.pdf
Also...
Taking this PWM dimmed Constant off time controlled sepic converter attached .....it is so easy to make stable...what is it about 'constant off time' that makes feedback compensation so much easier for it?...even in the SEPIC topology...("PWM dimmed SEPIC" schematic and ltspice simulation attached)
LM3421 DATASHEET:
Also...
