napatel81
Newbie level 3
PWM current control
I have a solenoid with 0-0.8mA current range driven using PWM. The coil resistance is 14ohms and inductance is 14mH. I am using an FPGA to do the closed loop current control, Servoing at 24K. The feedback current is read through a 1 ohm sense resistor. Required pwm resolution is 12bit.
Does anyone have enough experience to help me determine if this is a good configuration??
