eeefreakians
Newbie level 6
I have 135 watt Kyocera panels with a rated output of 17.7 volts at 7.63 amps. Using Ohm’s Law:
17.7 volts x 7.63 amps = 135.051 watts
However, 17.7 volts is not useful to the amateur radio operator. The voltage needs to be converted down to approximately 13.5 volts to support a 12 volt battery and run amateur radio gear. Keep in mind that on a PWM solar controller, the output current will never exceed the input current:
13.5 volts x 7.63 amps = 103.005 watts.
my question
why doesnt the current change??? say in a boost converter ,will reduce the current and boost voltage. what am i missing here??
why the current isnt altered in PWM charge controller??
my question
