bowman1710
Full Member level 3
- Joined
- Nov 8, 2014
- Messages
- 183
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 18
- Activity points
- 1,604
Hi guys,
I'm looking at a push-pull topology (open loop) with and input of 50V (regulated) and 350V output at 200W. If its open loop (i.e the output will not be regulated) I take it I will need a 1:7 turn ratio on the transformer. I have had issues in the past with the turns ratio being too low causing the magnetising inductance to be to large, so what will be the minimum number of turns in the primary, while keeping the magnetising inductance low? I need to try and keep the design as small as possible (ideally with a planar design if possible).
