Nov 29, 2019 #1 A adnan012 Advanced Member level 1 Joined Oct 6, 2006 Messages 468 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 4,923 hi, I want to design a isolated push-pull converter using UC3846 pwm controller. Specs are V(in) = 10-18VDC V(out) = 100VDC I(out) = 6 Amps I can implement non isolated version. I need help in the implementation of isolated voltage feedback loop using TL431 and opto-coupler. Regards
Nov 29, 2019 #2 E Easy peasy Advanced Member level 6 Joined Aug 15, 2015 Messages 4,745 Helped 1,402 Reputation 2,804 Reaction score 1,932 Trophy points 1,393 Location Melbourne Activity points 26,207 Hello, 600 watts out = 60ADC in, so the turns ratio needs to be at least 1:10 ( 10V to 100V ) more to allow for losses. push-pull is OK but the Tx needs to be low leakage L from pri to pri & pri's to sec ... there are loads of app notes showing how to use TL431 & opto to get a signal to the pri side the op-amp on the 3846 needs to be configured as a unity gain follower good luck ...
Nov 29, 2019 #3 A adnan012 Advanced Member level 1 Joined Oct 6, 2006 Messages 468 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 4,923 I will be very thankful to you can provide some documents. I need some detailed theory regarding loop compensation etc. Regards
