Hi everyone
I need help with writhing this combinational ALU
Here is my code
Code VHDL - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
| library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity PocketCalculator is
Generic (Bits : integer := 8);
Port ( Input_1 : in STD_LOGIC_VECTOR (Bits-1 downto 0):=(Others =>'0');
Input_2 : in STD_LOGIC_VECTOR (Bits-1 downto 0):=(Others =>'0');
Select_Operator : in STD_LOGIC_VECTOR (2 downto 0):=(Others =>'0');
Output : out STD_LOGIC_VECTOR (Bits-1 downto 0):=(Others =>'0'));
end PocketCalculator;
architecture Behavioral of PocketCalculator is
begin
Process(Input_1,Input_2,Select_Operator)
Begin
Case Select_Operator is
When "100" =>
Output <= Input_1 + Input_2;
When "010" =>
-- Right here I have to do the multiply part,
-- and I dont know what to write here
When "001" =>
Output <= Input_1 + not Input_2 + 1;
When Others =>
NULL;
End Case;
End Process;
end Behavioral; |
and here are my problems
1- I want to add two 8-bit inputs (input_1 and Input_2) WITH CARRY!!!
so Output should be a 9-bit signal or port.
but when I define Output as a 9-bit port, a warining comes up in synthesize
and an error comes up during simulating with ISIM (The simulator is stopped)
So what should I do to add two 8-bits and put it in a 9-bit signal or port?
2- My secend problem is with multiplying part.
I want to use the Output port right here but it should be 16-bit port.
first : i dont know the code or function that does this on std_logic_vector
secend : if I define output as a 16-bit port, I will be facing some other problems with adding part
Please help me, I am really confused
Hi Guys
I wrote a new code and it seems to work correctly
what do you think about this one
library IEEE;
use ieee.numeric_std.all;
Select_Operator : in STD_LOGIC_VECTOR (2 downto 0):=(Others => '0');
Output : out STD_LOGIC_VECTOR ((2*Bits)-1 downto 0):=(Others =>'0'));
Signal Add_Result,Sub_Result : Std_logic_vector (Bits downto 0):= (Others=>'0');
Signal Mul_Result : Std_logic_vector ((2*Bits)-1 downto 0):= (Others=>'0');
begin
Add_Result <= ('0' & Input_1) + ('0' & Input_2);
Sub_Result <= ('0' & Input_1) + (not ('0' & Input_2)) + 1;
Mul_Result <= Input_1 * Input_2;
Output <= "0000000" & Add_Result when Select_Operator="100" else
std_logic_vector(resize(Signed(Sub_Result),16)) when Select_Operator="010" else
Mul_Result when Select_Operator="001" else
(Others =>'0');
end Behavioral;
