I have problem to make a pwm with high frequency and high resolution. I´m using a internal clock of 160 MHz and I get a pwm of 1.25 MHz and a resolution of 4 bits. I have made my pwm by using a comparator a ROM-table and 2 counters.
How do I do to make a pwm with higher resolution och higher frequency?
How is this made for example for pwm for audio, are they using more outputs to make more resolution?
To create a 4 bit pwm with a compartor to compare a counter with a ROM-table it will be 7 bits lower frequency (if detecting on both falling and rising edge on the clk else it will be 8 bits). Se attachment "pwm_scheme" on the scematic.
I hope it can be done in another way.
I´m going to create a sinus (5-10 MHz) with as high resolution a possible.
My internal clk alternative is max. 500-600 MHz.
It seem that sigma delta modulation is for lower frequency, and by that it is possible to get higher resolution?
