pullup resistor in ltspice
vamsee
Full Member level 1
i am newbie in ltspice. can anyone help me in drawing this circuit..
Reactions: bassa
    bassa
The resistor is at the top of the LTspice window.
The 74HC04 logic inverter and simple switch are not standard models in LTspice.
There is a device labeled "sw" which is a voltage controlled switch that can be used for the switch in your diagram. Otherwise there are some switch models located at the Yahoo LTspice Users Group.
I believe the Yahoo LTspice Users Group also has a 74HC library which you can download and install. The LTspice manual tells you how to install additional libraries.
If you just need a generic model, there is a "inv" device in LTspice that performs the ideal inverter function.
