PullBack_Zone&TraceWidth_Help
hot_snow
Junior Member level 1
Hello,
When I make a multilayer board with planes, I see a green zone in the edges of my Board which is the pullback zone.
can I route traces or add pads in this green zone?
Also, I'm using a model board for my design. In this model board the trace width is 0.2mm, clearance is 0.2 mm and pads hole is 0.254mm.
I deacrease the upper values because my board is small to: 0.127mm for trace width, clearance is 0.127 mm and pads hole is 0.2mm.
Do you think that these new values can affect the signal transfer of my board ?
Thanks,
