Pull up RB1 on pic18f2520
kle0ps
Junior Member level 2
Hello guys.
Does anyone know how to pull up only RB1 on PIC18F2520?
I use C18 compiler
Thank you
Hello mate
I know that, but i want to connect my pic18f2520 with arduino. i want to sent HIGH (3-5V) from RB1 to arduino only when I want, not continuously
Then write the code to make pin RB1 high or low according to your need.
I set PORTB as ouputs and i set PORTBbits.RB0==1; (HIGH) but when i measure the voltage on RB0 was zero
Finally i fix it. I change PORTBbits.RB0==1 to PORTA=0b00000001;
Thank you mate!
When you want to write to a bit or a register, you use only = , not ==.
Like you used
PORTBbits.RB0 = 1;
If you want to check/compare, then you use == instead of =.
if (PORTBbits.RB0 ==1){
if (PORTD == 255){
Hope this helps.
Tahmid.
