So you want us to provide an answer to your (apparent) homework question so you don't have to do the research?
Will that work for you when you are on the job and have a similar question that needs an answer?
I know that writing KCL and KVL will give the answer (possibly true for most of the circuit questions) and I know the answer too. What I wanted is an intuitive explanation.
"Fully" versus "pseudo differential" circuit is just a general design principle and doesn't designate an actual circuit topology. Although one could guess that "fully differential" involves good PSRR due to symmetry properties, the question should refer to a specific circuit.
I guess you have a circuit in mind when you say, you know the answer. You should refer to it when expecting "clear explanations"...
