Pspice - Saw tooth / Vramp
abbey
Junior Member level 1
abbey
Does anyone know where i can find a library for pspice that includes Vramp?? (I have 9.2 Edition) Cause I am trying to generate a saw tooth pulse for a circuit. Thank you
When you select the pulse waveform, you can play with the rise and fall time of the pulse to make a saw tooth pulse, even with different rise and fall time.
Make the pulse duration very short to get a sharp top.
Added after 1 minutes:
for example: tr=1m, tf=0.99m, tp=0.01m, period = 2ms
WimRFP said:
Thank you very much!It worked!
Added after 21 minutes:
shall i use the same part (vpulse) in order to generate a rectangular pulse? is there any better way?
