Pspice InAmp AD620 model not working
middlehein
Newbie level 5
So I am trying to model a AD620 inamp from anolog devices and have their Lib with the AD620 in it and am trying to use that with a basic circuit. I am new to Capture CIS pspice and cannot seem to get the circuit to work without the convergence failing. I thought it might be a floating ref point, but everything is grounded so I am not sure where I am going wrong here. Below is the output and a picture of the circuit.
** Creating circuit file "sweep.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Cadence\SPB_16.3\tools\PSpice\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.TRAN 0 100ms 0
.OPTIONS STEPGMIN
.PROBE N([N00559])
.PROBE N([N00480])
.PROBE N([N00493])
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source SCIM IN-AMP TEST
X_U1 N00493 N00489 N00572 N00965 N00559 0 N00180 N00187 AD620/AD
C_C1 N00480 N00493 .1u TC=0
C_C2 N02797 N00489 .1u TC=0
R_R1 N00187 N00180 10meg TC=0,0
C_C3 N00572 0 .33u TC=0
C_C4 N00572 0 .01u TC=0
C_C5 N00965 0 .33u TC=0
C_C6 N00965 0 .01u TC=0
R_R2 N00493 0 1meg TC=0,0
R_R3 0 N00559 1k TC=0,0
V_V1 N00480 0
+SIN 0 1 1000 0 0 0
V_V2 N00572 0 15Vdc
V_V3 0 N00965 -15Vdc
V_V4 N02797 0
+SIN 0 1 500 0 0 0
R_R4 N00489 0 1meg TC=0,0
**** RESUMING sweep.cir ****
.END
**** 08/04/12 20:22:37 ******* PSpice 16.3.0 (June 2009) ****** ID# 0 ********
** Profile: "SCHEMATIC1-sweep" [ C:\Users\heinx055\Desktop\Circuit anaylsis\scim in-amp test-pspicefiles\schematic1\sweep.sim ]
**** Diode MODEL PARAMETERS
X_U1.DX X_U1.DY
IS 1.000000E-12 1.000000E-12
BV 50
**** BJT MODEL PARAMETERS
X_U1.QN1 X_U1.QN2
NPN NPN
LEVEL 1 1
IS 100.000000E-18 100.000000E-18
BF 10.000000E+03 250
NF 1 1
BR 1 1
NR 1 1
ISS 0 0
RE 0 0
RC 0 0
CJE 0 0
VJE .75 .75
CJC 0 0
VJC .75 .75
MJC .33 .33
XCJC 1 1
CJS 0 0
VJS .75 .75
KF 700.000000E-18 5.000000E-15
AF 1 1
CN 2.42 2.42
D .87 .87
ERROR -- Convergence problem in transient bias point calculation
Last node voltages tried were:
NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE
(N00180) -.6352 (N00187) -.6355 (N00480) 0.0000 (N00489)-309.0E-06
(N00493)-583.9E-06 (N00559) 12.4040 (N00572) 13.7430 (N00965) 13.7430
(N02797) 0.0000 (X_U1.3)-584.1E-06 (X_U1.4)-309.1E-06 (X_U1.5) 13.2850
(X_U1.6) 13.2850 (X_U1.9) -.6352 (X_U1.10) -.6355
(X_U1.11) 13.2850 (X_U1.12) 13.7000
(X_U1.13) 13.7430 (X_U1.14) 13.1260
(X_U1.15) 13.7000 (X_U1.16) 13.7430
(X_U1.17) 13.1260 (X_U1.18) 13.1060
(X_U1.19) -.6356 (X_U1.21)-570.4E-06
(X_U1.25) 13.6520 (X_U1.26) 12.3420
(X_U1.27) 14.9620 (X_U1.36) 1.0545
(X_U1.38) 12.5920 (X_U1.40) 13.5630
(X_U1.41) 13.9160 (X_U1.42) 10.8920
(X_U1.43) 13.1880 (X_U1.44) 64.1980
(X_U1.45) 12.4040 (X_U1.51) 13.1020
(X_U1.52) 13.1020 (X_U1.53) 14.3850
(X_U1.54) 14.3850 (X_U1.98) 12.5920
These voltages failed to converge:
V(N00559) = 12.48V \ 12.40V
V(X_U1.38) = 13.74V \ 12.59V
V(X_U1.98) = 13.74V \ 12.59V
V(X_U1.40) = 13.66V \ 13.56V
V(X_U1.36) = -446.46uV \ 1.055V
V(X_U1.45) = 12.48V \ 12.40V
V(X_U1.41) = 13.99V \ 13.92V
V(X_U1.42) = 10.97V \ 10.89V
These supply currents failed to converge:
I(X_U1.EREF) = 12.50nA \ 12.44nA
I(X_U1.E3) = 13.74uA \ 11.54uA
I(X_U1.L1) = 9.480mA \ 9.394mA
I(V_V2) = 10.00GA \ 10.00GA
I(V_V3) = 10.00GA \ 10.00GA
I(X_U1.V6) = -10.00GA \ -10.00GA
I(X_U1.V7) = -10.00GA \ -10.00GA
ERROR -- Discontinuing simulation due to convergence problem
**** Interrupt ****
Try using solver 0 instead of 1 (1 is the default). You can change it in simulation settings -> options -> advanced.
just tried solver 0, and it again failed. One thing I notice is that it says the device X_U1.D14 failed to converge which seems to always be the problem. Is there maybe something wrong with the AD620 model?? I cant figure this out.
You want V3 to be +15 instead of -15. Change it and see if that helps.
I just tried your circuit and it converged fine with solver 0 and correct V3 -- in all other cases it failed to converge.
Yes, a typical error. Allocating a negative value to a negative voltage source will result in a positive value.
Major thanks to you, that seems to have solve the problem and made me realize what a idiot I am. I had looked at that though it appeared the power source was right because I had - to - and + to +, I completely overlooked that double negative.
No worries and that is a really common mistake. Save the self-abuse for when you make a stupid mistake that actually deserves it. :lol:
Glad you got it working. Convergence problems are generally a pain - not really the thing you want to be spending design time on.
sorry one quick question, I am wandering what are the different solvers.
I am not too familiar with the technical details of the solvers, so I can't give you a detailed answer. Solver 0 is the original PSpice algorithm, Solver 1 (the default) was introduced in a later version with a claimed performance increase.
From the PSpice manual back from ver 10.2:
(Solver = 0 selects the original solution algorithm;
Solver = 1 selects the advanced solution algorithm)
Default: 0 (In PSpice A/D Basics), 1 (In all other PSpice products)
Later it goes on to say:
However, I generally experience more convergence problems, especially with simpler circuits, using algorithm 1.
From ftp://ftp.ehu.es/cidira/dptos/depjt/sistemas de potencia/transparencias/guia sobre convergencia.pdf:
Solver 1 and Solver 0 are two matrix solving algorithms used by PSpice. By default, Solver 1 that has better convergence property, is used. But at times, for a circuit with convergence problems changing the simulation algorithm to Solver 0 helps.
A general rule of thumb seems to be: Try it with solver 1, and if it fails and you've checked your circuit for obvious errors, try it with solver 0.
That's not true. Solver 1 is faster and would have superior convergence for most of circuits. PSpice 16.3 also has AUTOCONVERGANCE feature. Which would work for majority of circuits.
