i have to generate a 64 bit length pseudorandom sequence. I mean to code in VHDL. Is there a necessity for knowing the polynomials that are required for genereating the sequence... or how to know from which of the register i have to tap the output??? i wanted to know this method for generating any length PN sequence. or any other way out is there? pls help me...
there are some books which have existing circuits.
so you can use it directly.
one book named "scrambling and discrambling", maybe it is.
i am not sure. i ever read it.
this book is wrote by two Koreans.
Hello Everyone. I need to generate a binary data stream of duration Ts. After, I need to collect the even bits to create the in phase stream and stretch these slot in duration 2Ts.
