Proton + application program to PORTC KEYPAD_PORT command?
vasili35
Proton + Program "KEYPAD_PORT = PORTB" command using the keypad and works in PORTB. but if we have to attach the keypad, the command will be the other ports .. I "KEYPAD_PORT = PORTC" doing everything mixed up .. but you have an idea of the ?
Your question is not clear. Post your circuit schematic (eq Proteus DSN) and your program here.
Isis my file and Proton "basic" I shared my schedule. Proton + I just want to write this program. Thank you...
Thanks vasili35, I got your project, I will examine later. Please be patient ...
Because PORTB has internal pullups but PORTC doesn't.
Attached the modified working project (your lookup table is also modified by me).
Good luck.
PS:
I'm using Proton PDS 3.4.0.8 and Proteus v7.7sp2
  • Keypad-2.zip
zuisti thank you. recommendations and the code worked for me .. Yes the problem is a kind of pull up, I knew that but could not find solution .. You saved me from using the 2nd pic you will use the solution :)...
