biswajitdas49
Member level 3
- Joined
- May 17, 2012
- Messages
- 55
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- WEST BENGAL,INDIA
- Activity points
- 1,726
I write a code in assembly for 16x2 lcd display,but it does not display the ASCII code which given in the code.I use pic16f1936 uC at 4 MHz internal osc. My display interface is 8 bit mode with my controller.
Now my problem is when I start the animation play button, all the connected pin work as well,but it display nothing.I don't understand what's wrong with my code or the pin connection,or anything else may be connected with this pin.
please some body help me!!!!!!!!!!!!!
my proteus lcd interface image is here-
here is my code:-
here is my code:-
; This file is a basic code template for code generation on the *
; PIC16F1936. This file contains the basic code building blocks to build *
; upon. *
; Refer to the MPASM User's Guide for additional information on *
; features of the assembler. *
; Refer to the respective data sheet for additional *
; information on the instruction set. *
; Filename: xxx.asm *
; Date: *
; File Version: *
; Author: *
; Company: *
; Files Required: P16F1936.INC *
; Notes: *
; Revision History: *
list p=16f1936 ; list directive to define processor
#include <p16f1936.inc> ; processor specific variable definitions
; CONFIGURATION WORD SETUP
; The 'CONFIG' directive is used to embed the configuration word within the
; .asm file. The lables following the directive are located in the respective
; .inc file. See the data sheet for additional information on configuration
; word settings.
__CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_ON & _IESO_OFF & _FCMEN_OFF
__CONFIG _CONFIG2, _WRT_OFF & _VCAPEN_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_19 & _LVP_OFF
; VARIABLE DEFINITIONS
; Available Data Memory divided into Bank 0-15. Each Bank may contain
; Special Function Registers, General Purpose Registers, and Access RAM
#DEFINE RS PORTC,4 ;pin no.15
#DEFINE EN PORTC,5 ;pin no.16
; #DEFINE DB7 PORTD,3
; #DEFINE DB6 PORTD,2
; #DEFINE DB5 PORTD,1
; #DEFINE DB4 PORTD,0
#DEFINE LINE1 0x80
CBLOCK 0x20 ; Define GPR variable register locations
LCD_CMD
LCD_DATA
PORTD_TEMP
VALUE_REG
VALUE_REG1
CounterA
CounterB
CounterC
CounterD
ENDC
SAMPLE1 EQU 0x7D ; Sample user registers
SAMPLE2 EQU 0x7E ;
SAMPLE3 EQU 0x7F ;
; EEPROM INITIALIZATION
; The 16F1936 has 256 bytes of non-volatile EEPROM, starting at address 0xF000
DATAEE ORG 0xF000
DE "MCHP" ; Place 'M' 'C' 'H' 'P' at address 0,1,2,3
; RESET VECTOR
ORG 0x0000 ; processor reset vector
PAGESEL START
GOTO START ; When using debug header, first inst.
; may be passed over by ICD2.
; INTERRUPT SERVICE ROUTINE
ORG 0x0004
; USER INTERRUPT SERVICE ROUTINE GOES HERE
; Note the 16F1936 family automatically handles context restoration for
; W, STATUS, BSR, FSR, and PCLATH where previous templates for 16F families
; required manual restoration
RETFIE ; return from interrupt
; MAIN PROGRAM
START
; PLACE USER PROGRAM HERE
CALL INITIALIZATION
CALL LCD_INIT
CALL SEND_DATA
GOTO $
INITIALIZATION
BANKSEL OSCCON
MOVLW B'01101010' ;Fosc 4MHZ
MOVWF OSCCON
BANKSEL PORTC
CLRF PORTC
BANKSEL LATC
CLRF LATC
BANKSEL TRISC
CLRF TRISC
banksel PORTB
clrf PORTB
banksel ANSELB
clrf ANSELB
banksel TRISB
CLRF TRISB
RETURN
LCD_INIT
CALL LONG_DELAY
MOVLW B'00110000' ;Function set
CALL WRITE_CMD
CALL WRITE_CMD
CALL WRITE_CMD
MOVLW B'00111000' ;Sets to 8-bit operation and selects 2-line display and 5*8 dot character font
CALL WRITE_CMD
MOVLW B'00001000' ;Turns on display and cursor,All display is in space mode because of initialization.
CALL WRITE_CMD
MOVLW B'00000001'
CALL WRITE_CMD
MOVLW B'00000110'
CALL WRITE_CMD
MOVLW B'00001100'
CALL WRITE_CMD
MOVLW B'10000000'
CALL WRITE_CMD
CALL LONG_DELAY
RETURN
SEND_DATA
MOVLW A'S'
CALL WRITE_DATA
MOVLW A'W'
CALL WRITE_DATA
MOVLW A'A'
CALL WRITE_DATA
MOVLW A'J'
CALL WRITE_DATA
MOVLW A'I'
CALL WRITE_DATA
MOVLW A'T'
CALL WRITE_DATA
MOVLW A'T'
CALL WRITE_DATA
RETURN
WRITE_CMD
BANKSEL PORTB
MOVWF PORTB
BANKSEL PORTC
BCF PORTC,4 ;RS pin
; CALL DELAY_5mS
BSF PORTC,5 ;enable pin
CALL DELAY_200uS
BCF PORTC,5
; CALL DELAY_40mS
RETURN
WRITE_DATA
BANKSEL PORTB
MOVWF PORTB
BANKSEL PORTC
BSF RS
; CALL DELAY_5mS
BSF PORTC,5
CALL DELAY_200uS
BCF PORTC,5
; CALL DELAY_40mS
BSF PORTB,0
RETURN
LONG_DELAY
movlw D'16'
movwf CounterC
movlw D'57'
movwf CounterB
movlw D'205'
movwf CounterA
loop0
decfsz CounterA,1
goto loop0
decfsz CounterB,1
goto loop0
decfsz CounterC,1
goto loop0
retlw .0
DELAY_40mS
movwf CounterB
movlw D'241'
movwf CounterA
loop1
decfsz CounterA,1
goto loop1
decfsz CounterB,1
goto loop1
retlw .0
DELAY_5mS
movlw D'7'
movwf CounterB
movlw D'231'
movwf CounterA
loop2
decfsz CounterA,1
goto loop2
decfsz CounterB,1
goto loop2
retlw .0
DELAY_200uS
movlw D'26'
movwf CounterB
movlw D'247'
movwf CounterA
loop3
decfsz CounterA,1
goto loop3
decfsz CounterB,1
goto loop3
retlw .0
DELAY_53uS
movlw D'7'
movwf CounterB
movlw D'224'
movwf CounterA
loop4
decfsz CounterA,1
goto loop4
decfsz CounterB,1
goto loop4
retlw .0
END
