Proteus simulation of MOSFET Voltage inverter gives DC output, How to correct this?
umat
Newbie level 3
Hello,
My DC to AC converter circuit (attached) does not produce AC output. I have connected a pulse generator to one pair of the bridge switches. The other pair is connected from the same pulse source except that the inputs are inverted through a not gate.
I intend to replace the pulse generators with microcontroller PWMs after I get the circuit working.
Kind regards.
Your mosfets are P-type. The bias is referenced to the more positive terminal. To turn off a P-device, requires the bias voltage be same level (pretty much) as the positive supply voltage. Since your supply is 200V, then it looks as though your mosfets are never shutting off.
To get the mosfets to switch on and off, try reducing Bat3 to a lower voltage, namely the same voltage produced by U2 (invert gate).
Reactions: umat
    umat
I have changed my transistors to N-Channel type MOSFETs, (does this seem better?) and have also changed the connections as shown below. My task is to convert a 200V DC to an AC value, hence Vbat is 200V.
Is there any way I can switch on and off the MOSFETs with my without changing my Vbat?
Flipping supply voltage and transistor polarity doesn't turn it into a working circuit. Looks like you have seen a principle schematic of a full bridge and thought it a real circuit.
You need isolated or level shifting gate drivers for the high side. Also dead time generation to avoid bridge shoot-through.
Reactions: umat
    umat
Typical method, low voltage signal controls high voltage to load.
The 40k resistor needs to be adjusted so it provides desired performance. It dissipates 1W of heat with my simulation parameters. It will be a different amount in your circuit.
Reactions: umat
    umat
I'll incorporate gate drive circuit for my MOSFETs or opt for BJT transistors as used Brad's circuit
