Proteus simulating "pc=54ae9b8 is outside of ROM space
omid_juve
Full Member level 1
Full Member level 1
i write a program in bascom avr and it is compiled for about 70% . but unfortunately when i have run it in proteus . i got so many error of "pc=54ae9b8 is outside of rom space. plz read my code and tell me what can i do to simplify my code . my code is about reading the turns of the motor through using encoder pulses comes to int0 and save the position of the motor every time in nvram of ds1307 .
i want to know also in real world i will have this issue or not .
Thanks
Code Basic4GL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
$regfile = "m8def.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 40
Cursor Off
Config Lcdpin = Pin , Db4 = Pinb.2 , Db5 = Pinb.3 , Db6 = Pinb.4 , Db7 = _
Pinb.5 , E = Pinb.1 , Rs = Pinb.0
Config Lcd = 16 * 2
Waitms 300
Dim A1 As Byte
Dim W1 As Integer
Dim Step1 As Integer
Dim C4 As Integer
Dim K2 As Integer
Dim Comp1 As Single
Dim W2 As Single
Dim C1 As Single
Dim W3 As Single
Dim Ad As Byte
Dim X As Byte
Dim Direction As Byte
Dim Comp As Integer
Dim Originplace As Byte
Config Pind.2 = Input
Config Pind.3 = Input
Config Pinc.0 = Input
Config Pinc.1 = Input
Config Pinc.2 = Input
Config Pinc.3 = Input
Config Pind.7 = Input
Config Pind.6 = Input
Config Portd.4 = Output
Config Portd.0 = Output
Config Portd.1 = Output
Config Portb.6 = Output
$lib "I2c_twi.lbx" ' we do not use software emulated I2C but the TWI
'Config I2cdelay = 10
Config Scl = Portc.5 ' we need to provide the SCL pin name
Config Sda = Portc.4 ' we need to provide the SDA pin name
I2cinit
Config Twi = 100000 ' wanted clock frequency when using $lib "i2c_twi.lbx"
'will set TWBR and TWSR
'Twbr = 12 'bit rate register
'Twsr = 0 'pre scaler bits
Up Alias Pinc.3
Down Alias Pinc.2
Zero Alias Pinc.1
Reset1 Alias Pinc.0
Ent Alias Pind.7
Bl Alias Portd.4
Enk1 Alias Pind.2 'Encoder pin A
Enk2 Alias Pind.3
Startm Alias Pind.6
Leftm Alias Portd.0
Rightm Alias Portd.1
Status Alias Portb.6
Const Ccw = 0
Const Cw = 1
Const Quarterturn = 25
Const Fullturn = 100
Const Dsread = &B11010001
Const Dswrite = &B11010000
Declare Sub Writing(byval A As Byte , Byval Address As Byte)
Declare Sub Entering
Declare Sub Resetsub
Declare Sub Origin
Declare Sub Save1(byval W33 As Integer , Address1 As Byte)
Declare Sub Reading(a As Byte , Byval Address As Byte)
Ad = 7
X = &B00010000
Call Writing(x , Ad)
Ad = 0
Call Reading(x , Ad)
If X.7 = 1 Then
Reset X.7
Ad = 0
End If
Ad = 9
C4 = X
Shift C4 , Left , 8
Decr Ad
C4 = C4 Or X
Ad = 11
W1 = X
Shift W1 , Left , 8
Decr Ad
W1 = W1 Or X
Ad = 13
Step1 = X
Shift Step1 , Left , 8
Decr Ad
Step1 = Step1 Or X
Ad = 14
A1 = X
Ad = 15
Originplace = X
C1 = Step1 / 100
Cls
A1 = 2
If A1 <> 1 Or A1 <> 0 Then
Cls
Lcd "plz set the"
Locate 2 , 1
Lcd " turn no.!!!"
End If
Waitms 200
Config Int0 = Falling
Enable Int0
On Int0 Enkoder_sub
Enable Interrupts
'The Encoder_sub subroutine is very simple:
Do
Debounce Ent , 0 , Entering , Sub
Reset Watchdog
Loop
Enkoder_sub:
Reset Watchdog
If Originplace = 1 Then
Locate 2 , 1
C1 = C4 / 100
Set Bl
Decr C4
Lcd "step=" ; Fusing(c1 , "#.##")
If C4 < 0 Or C4 = 0 Then
C4 = 0
Ad = 8
Call Save1(c4 , Ad)
C1 = 0
Step1 = 0
Originplace = 0
Ad = 15
Call Writing(originplace , Ad)
Cls
Lcd "reached"
C4 = 0
C1 = 0
A1 = 2
Comp = W3 * Fullturn
Step1 = Quarterturn
Ad = 12
Call Save1(step1 , Ad)
Reset Rightm
Reset Leftm
Wait 1
A1 = 0
Reset Rightm
Set Leftm
End If
Else
Reset Bl
Direction = Cw
Incr C4
If C4 > Step1 Or C4 = Step1 Then
C1 = Step1 / Fullturn
If Comp = Step1 Then
Comp = Comp * 2
Comp1 = Comp / 100
If Comp1 > W2 Then
Toggle A1
C4 = 0
Step1 = 0
Else
Toggle A1
End If
End If 'up sub
Step1 = Step1 + 25
Ad = 12
Ad = 8
Call Save1(c4 , Ad)
End If
'save a1(rotation)
Ad = 14
Call Writing(a1 , Ad)
If A1 = 0 Then
Locate 1 , 1 'test of encoder if performs OK
Lcd "turn= " ; Fusing(c1 , "#.##") ; " ccw"
Reset Rightm
Set Leftm
Elseif A1 = 255 Then
Locate 1 , 1
Lcd "turn= " ; Fusing(c1 , "#.##") ; " cw"
Set Rightm
Reset Leftm
End If 'if OK, then C1 wil be incr/decr in 1
Locate 2 , 1
Lcd "set= " ; Fusing(w2 , "#.##")
End If
Debounce Zero , 0 , Origin , Sub
Debounce Reset1 , 0 , Resetsub , Sub
Return
End
Sub Entering
Set Bl
Reset Leftm
Reset Rightm
Cls
Disable Interrupts
Waitms 500
If W2 < .5 Then
W2 = .5
Elseif W2 > 9.5 Then
W2 = 9.5
End If
Do
Reset Watchdog
Waitms 200
If Up = 0 Then
W2 = W2 + .5
If W2 > 9.5 Then W2 = 9.5
Elseif Down = 0 Then
W2 = W2 - .5
If W2 < .5 Then W2 = .5
End If
Waitms 10
Locate 2 , 1 'test of encoder if performs OK
Loop Until Ent = 0
W3 = W2 / 2
W1 = Comp
Ad = 10
Call Save1(w1 , Ad)
Step1 = Quarterturn
Ad = 12
C1 = 0
A1 = 0
Ad = 14
C4 = 0
Reset Rightm
Set Leftm
Cls
Enable Interrupts
End Sub
Sub Resetsub
Set Bl
Disable Interrupts
Reset Leftm
Reset Rightm
C4 = 0
C1 = 0
A1 = 0
Step1 = Quarterturn
Ad = 8
Call Save1(c4 , Ad)
Ad = 12
Ad = 14
Cls
Lcd "reset!!!"
Wait 1
Enable Interrupts
End Sub
Sub Origin
Set Bl
Toggle Status
Disable Int0
Reset Leftm
Reset Rightm
K2 = C4 - W1
If K2 > 0 Then
C4 = C4 - W1
End If
Originplace = 1
Ad = 15
If A1 = 0 Then
Toggle A1
Reset Leftm
Set Rightm
Toggle A1
Set Leftm
Reset Rightm
End If
Ad = 14
Call Writing(a1 , 14)
Cls
Locate 1 , 1
Lcd "originating..."
Enable Int0
Enable Interrupts
End Sub
Local B33 As Byte
Local B44 As Byte
B33 = W33 'save c4
Shift W33 , Right , 8
B44 = W33
Call Writing(b33 , Address1)
Incr Address1
Call Writing(b44 , Address1)
W33 = 0
B33 = 0
B44 = 0
End Sub
I2cstart
I2cwbyte Dswrite
I2cwbyte Address
I2cwbyte A
I2cstop
Waitms 5
End Sub
I2cstart
I2cwbyte Dswrite
I2cwbyte Address
I2cstart
I2cwbyte Dsread
I2crbyte A , Nack
I2cstop
Waitms 2
End Sub
