neazoi
Advanced Member level 6
Hi, I want to build a small keyer, to on/off key the final stage of my 100mW HF transceiver.
I would like it to be made with discrete components, yet have the ability to be controlled from the sound level of the sound blaster as well as the com/LPT ports and also manually, using the same plug (preferably a stereo mini jack).
At the past I have designed a similar circuit **broken link removed** which worked, but I would like to add a simple means of shaping the envelope to avoid key clicks. Is it enough to add a capacitor from the base of the BC547 to the ground for this purpose?
Also any other ideas for such keyers would be appreciated.
