willcharlton
Newbie level 5
- Joined
- Mar 16, 2011
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- St. Paul, MN
- Activity points
- 1,356
I am designing a device that regulates the flow rate of oxygen with a solenoid-type, pwm controlled proportional valve. This valve is a great product, but it's not as linear as I would like it to be. I have been searching for a device that I can put in series with the valve that can monitor the flow rate and provide an electrical signal, analog or digital, back to my control device (PIC24) in order to recalculate the duty cycle of the pwm port and more precisely tune in the flow rate. Does anyone know of a device that I can put in-line with my proportional valve to electrically monitor that actual flow rate? I think my problem is, for instance, I give the valve a 10% duty cycle and I just expect it to be 10% open, but I don't think the flow rate curve is that linear. So what I plan to do is use this electrical readout of the actual flow rate to readjust the pwm signal. Any ideas? Thanks.
