ehsanax
Newbie level 1
I have problems with atmega8 and em4095 RFID driver.
this firmware and cicuit is unstable and very Sensitive to switching and aow read range(2cm).
my code and schematic is attached.
please help me.
thanks .
$regfile = "m8def.dat"
$baud = 9600
$crystal = 8000000
$hwstack = 40
$swstack = 40
$framesize = 40
'Make SHD and MOD low
Config Portd.4 = Output
Portd.4 = 0
Shd Alias Portd.5
Config Shd = Output
Shd = 0
Boogh Alias Portd.2
Config Boogh = Output
Boogh = 1
Wait 3
Boogh = 0
Dim Tags(5) As Byte 'make sure the array is at least 5 bytes
Dim J As Byte
Dim A As Byte
Config Hitag = 64 , Type = Em4095 , Demod = Pind.3 , Int = @int1
Print "kara2000(serial port test)"
On Int1 Checkints Nosave
Config Int1 = Change
Enable Interrupts
Do
' Print "Check..."
If Readhitag(tags(1)) = 1 Then
Print Chr(2); 'this will enable INT1
For J = 5 To 1 Step -1
'Print Hex(tags(j)) ; ",";
A = Tags(j) / 16
A = A + 48
Print Chr(a);
A = Tags(j) Mod 16
A = A + 48
Print Chr(a);
Next
Print Chr(0); 'CHECK SUM
Print Chr(13);
Print Chr(10);
Print Chr(3);
Waitms 1000
'Print
Else
'Print "Nothing"
End If
Waitms 500
Loop
Checkints:
Call _checkhitag
Return
please help me.
thanks .
$baud = 9600
$crystal = 8000000
$hwstack = 40
$swstack = 40
$framesize = 40
Portd.4 = 0
Shd Alias Portd.5
Config Shd = Output
Shd = 0
Boogh Alias Portd.2
Boogh = 1
Wait 3
Boogh = 0
Dim J As Byte
Dim A As Byte
Enable Interrupts
Do
' Print "Check..."
A = Tags(j) / 16
A = A + 48
Print Chr(a);
A = Tags(j) Mod 16
A = A + 48
Print Chr(a);
Next
Print Chr(13);
Print Chr(10);
Print Chr(3);
Waitms 1000
Else
'Print "Nothing"
End If
Waitms 500
Loop
Checkints:
Call _checkhitag
Return
