Measuring RPM would mean simply measuring the period between pulses from your photodiode, then some clever maths (once you know how many pulses per rotation, and your CPU's osc frequency) to convert this revolutions-per-minute. However, in order to measure
direction, you'll need a second LED/photodiode pair, perhaps with its own set of holes in the plate. The holes should be at the same raduis (well, close..) but 90 degree's out of phase. In terms of your project this means that they should be 15+(15*90/360) degree increments. So if your holes are 0,15,30,45,60 degrees, the second set should be 3.75,18.75, 33.75, 48.75 etc..
The exact offset angle isn't particularly critical though, you could get away with 3,18,33,48.. degrees, because whilst you measure RPM with one set of holes, the other set is just there to provide a phase difference, so it simply has to be offset by an angle that is less than half of the original hole angle. (ie: with your 15 degree increments, you'll need 15+ something thats less than 15/2 = 7.5, so <3-5 degree's would be a good offset).
If you don't want to add more holes then the placement of your second photodiode is just as important, it must be 1/4 the distance between the holes on your plate. That is:
Raduis at which holes are drilled on plate = r = example 40mm.
Angle at which holes are drilled = 15
Number of holes = N = 360/15 = 24
Distance between holes = (2*pi*r)/ N
your photodiodes should be placed 1/4 of this distance apart..
Sounds complicated but here's a link that explains it well:
http://thedenneys.org/pub/robot/encoders/
Drilling holes is quite straight forward for building an encoder, the only downside being is, because the holes are small compared to the plate, you have very narrow pulse widths. The phase relationship can usually be as simple as an XOR function, but with short pulses, you would have to
measure the time between the two different photodiode pulses, as well as each ones period. Doable with a small micro, but a bit fiddly.
