Re: ADS with Verilog
i tried with exact steps you have mentioned in the document
but i ended up with the following status/error message,
Warning detected by hpeesofsim during netlist flattening.
Instance `X1':
`b0' is not a valid parameter for an instance of `DCO'. Ignoring it.
Instance `X1':
`b1' is not a valid parameter for an instance of `DCO'. Ignoring it.
Instance `X1':
`b2' is not a valid parameter for an instance of `DCO'. Ignoring it.
Instance `X1':
`b3' is not a valid parameter for an instance of `DCO'. Ignoring it.
Warning detected by hpeesofsim in topology check during circuit set up.
Number of nodes with only one device attached (topology corrected): 1
Warning detected by hpeesofsim during DC analysis `Tran1'.
A virtual resistance of 1 pOhms
was added to branch SRC4.i.
with an empty window , instead of the result windows that you have shown in the document,
waiting for your reply
The link seems to have changed over the time and now leads to somewhere else.
Here's the updated link:
https://www.edaboard.com/threads/61497/#post758754
