Jun 26, 2012 #1 L lgeorge123 Full Member level 2 Joined Jun 13, 2004 Messages 130 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Location Hong Kong Activity points 1,403 Can I use si8250 as programmable output ? If so , what is its min and max output voltage with 36V input ??
Jun 26, 2012 #2 H hakeen Full Member level 5 Joined Jun 16, 2005 Messages 240 Helped 44 Reputation 88 Reaction score 19 Trophy points 1,298 Activity points 2,783 Hi you can use si8250 for 36V systems.However you should not exceed abs max values of the device. App note AN259 in website explains design of 30-72V systems.Max efficiency is given as 86%. hope it helps. Cheers
