Programm using 8051 in c
hrn1
Depth (mm) Frequency(kHz)
2 8
3 3
4 2
5 1
For above table, Please send me the program using 8051 in C. Please............
Sorry for the mistake. The left side column is depth and right side column is frequency. by using microcontroller program in C, I want to generate those frequencies for their respective depth. This output of the program I want to give it to the gate of MOSFET in the inverter circuit.
I suggest, you try for yourself first. Then post your code here in the forum. Others can the help you towards a solution.
The forum is not meant to do the work for you
