[ARM] Program for a STM32F4 board in CoIDE
victorrr
Hello, i want to program a STM32F4 board in CoIDE so it can transmit a voltage to a pin and then stop for a while and then again transmit voltage to the pin. I want to program the board so it can send periodically voltage to a ultrasound transducer. It has to do something like this:
https://upload.wikimedia.org/wikipe...ycle_general.png/350px-Duty_cycle_general.png
Can someone help me please? I have programmed easy things like turning on the leds but i'm stuck for doing this.
Thank you very much
That is LED blinking. You want to control the power to Ultrasonic sensor module or what to send trigger pulse ? If you want to control the power to module then you have to use a relay, transistor or mosfer controlled by MCU.
well i want to connect the board to ultrasonic sensor throug a h-bridge ic. The idea is that it arrives to the ultrasonic sensor a periodically wave (the h-bridge is only for doing this wave positive or negative). The thing is that I need to program the board so it can make this "wave" periodically into a pin and connect that pin to the sensor.
