Program Counter using VHDL for Altera DE2 Board.
thoughtmaze
Newbie level 2
Newbie level 2
Hi guys noob here, first post. I need to design a program counter to satisfy the following schematic.
and here is my code so far. Now I'm pretty sure this is wrong. But I don't even know how to test this yet using QuartusII, hoping my TA will explain it this Monday. Would someone with more experience take a look and help me figure this out, in particular I am sure I implemented the inc (increment) condition wrong, that is, if inc is high then I should start the count from the output.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY pc IS
	PORT(
		clr : IN STD_LOGIC;
		clk : IN STD_LOGIC;
		ld  : IN STD_LOGIC;
		inc : IN STD_LOGIC;
		d   : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
		q   : INOUT STD_LOGIC_VECTOR(31 DOWNTO 0));
END pc;
ARCHITECTURE description OF pc IS
-- you fill in what goes here!!!
	SIGNAL Count:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
	BEGIN
		PROCESS (clk,clr,ld,inc)
		BEGIN
			IF clr='0' THEN
				Count<="00000000000000000000000000000000";
			ELSIF inc='1' THEN
				Count<=q;
			ELSIF (clk'EVENT AND clk = '1') THEN
				IF ld='1' THEN
					Count<=Count+4;
				ELSE
					Count<=Count;
				END IF;
			END IF;
		END PROCESS;
		q<=Count;
END description;
any help would be greatly appreciated, thanks in advanced.
