SINDHURI
Member level 2
Good afternoon one and all,
I want to know about the processing of ARM7 Microcontroller. I want to operate more than one load connected to the ARM7 LPC2148 Microcontroller. My Project is based on speech recognition technique, and to control the intensity of loads such as fan or light with commands such as "start fan off, start fan 66, start fan 33 and start fan 100" and same commands are used with light. There is a PC section to Convert the voice command into serial data. For Example if we give input as "start fan on" then the PC section will convert the data and is given to ARM7 Microcontroller through zigbee transceiver to perform the operation. In this there are two dimmer modules to control the intensity of light and fan.
My question is that when a serial data is given to the microcontroller to perform the operation regarding to the command such as "start light on" then how the ARM7 LPC2148 Microcontroller will process the data to operate that particular device or module only.
Please reply me as early as possible.
Thanks in Advance.
Thanks in Advance.
