i have a problem with XILINX webpack 6.2 .
My Design is working when i'm doing a behavioral, post-translate and post-map simulation. But after the place&route the simulation fails.
The results of the simulations are attached.
Does Webpack a wrong Place & Route?
Can somebody explain that to me?
For the unequivocal answer there is enough information.
- Try to check up timing reports on conformity time restrictions of your
project. If necessary change timing constraints.
- Check up set/reset conditions.
- Check up the list of the removed and optimized nets and blocks.
