gemma_g
Newbie level 2
- Joined
- Apr 7, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,308
Hi guys, i am having a problem with the function and could really do with some help... probably best if i jsut show you the code to explain
so...(giving you everything here)...
-- signal declarations
type t_DDR2_MEMSPACE_CFG_REC is
record
start_address : std_logic_vector(g_DDR2_CTLR_ADDR_WIDTH-1 downto 0);
end_address : std_logic_vector(g_DDR2_CTLR_ADDR_WIDTH-1 downto 0);
end record;
type t_ARRAY_DDR2_MEMSPACE_CFG_REC is array(natural range <>) of t_DDR2_MEMSPACE_CFG_REC;
signal ddr2_memspace_cfg : t_ARRAY_DDR2_MEMSPACE_CFG_REC(st_CHANNELS_RANGE) := (others => c_DEFAULT_VAL_MEM_CFG);
-- i declare these signals inside a generate (for c in st_CHANNELS_RANGE)
signal wr_addr : unsigned(15 downto 0) := (others => '0');
wr_address_gt_memory_end : std_logic := '0';
throughout the rest of the code these are all good - i can read/write them, compile and simulate nae bother, but, when i try and do the following assignment Modelsim is not a happy chappy..
wr_address_gt_memory_end(c) <= '1' when std_logic_vector(resize(unsigned(wr_addr(c)), g_DDR2_CTLR_ADDR_WIDTH)) > ddr2_memspace_cfg(c).end_address) else '0';
--- errors
No feasible entries for subprogram "RESIZE".
Cannot resolve expression type of infix expression.
Illegal type conversion to ieee.std_logic_1164.STD_LOGIC_VECTOR (operand type is not known).
Type conversion (to ieee.std_logic_1164.STD_LOGIC_VECTOR) conflicts with expected type std.STANDARD.BOOLEAN.
i've had problems with resize before - usually brackets in the wrong place, that kind of thing but i am starting to pull my hair out over this one and am sure i am just making some kind of schoolboy error with it, just can't work out what.. grrrr
can anyone throw any light on it for me???? (have all the correct libs for resize and use it elsewhere in the code already)
cheers in advance,
gems
record
end record;
--- errors
cheers in advance,
gems
