Problems with ISE 11 on Windows 7
tlp71@hotmail.com
Full Member level 4
ise11 on seven
hi, i installed ise 11.1 in seven and all seems work fine.
i tried to update to 11.4 s.p
but the setup doesen't start.
hany have the same trouble?
my 7 is 64 bit.
tks for help.
bye.
G.
vlsi_freak
Full Member level 2
Re: ise11 on seven
This can be done easily. No specific set up required for 64 bit.
Ensure that your OS supports 64 bit application.
regards,
freak
Jack// ani
Advanced Member level 3
ise11 on seven
I'm running ISE 11 on windows 7, however, its 32-bit.
Maybe you could try running the service pack in compatibility mode for Windows XP.
Good luck
tlp71@hotmail.com
Full Member level 4
Re: ise11 on seven
yes ise 11 running but i can't update.
i downloaded all the package but setup.exe doesen't run
