Mohammad Zubair
Junior Member level 3
Hello
I am working on inverter. I have some problems going with it.
Here is the code I am using. I am giving pulses from an ATMEGA162 Micro controller.
I am working on hardware. Final Hardware will be driven by another series of micro controller. So I am not very good with this code. I am applying +DC Bus of 30V
Problems I am having are:
IGBTs are getting very heated up.
a) I think by putting dead time, it will solve the problem. But I am not sure how to put it in this code. Any help
b) or if there is anything else which might be wrong with the inverter. Please do guide
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 #define f 400 #define spc 24 #define adj 6 #define Phase1L PORTC.0 #define Phase1H PORTC.1 #define Phase2L PORTC.2 #define Phase2H PORTC.3 #define Phase3L PORTC.4 #define Phase3H PORTC.5 flash unsigned char PWMCodes[721]={0,0,4,9,13,18,22,27,31,35,40,44,49,53,57,62,66,70,75,79,83,87,91,96,100,104,108,112,116,120,124,127,131,135,139,143,146,150,153,157,160,164,167,171,174,177,180,183,186,190,192,195,198,201,204,206,209,211,214,216,219,221,223,225,227,229,231,233,235,236,238,240,241,243,244,245,246,247,248,249,250,251,252,253,253,254,254,254,255,255,255,255,255,255,255,254,254,254,253,253,252,251,250,249,248,247,246,245,244,243,241,240,238,236,235,233,231,229,227,225,223,221,219,216,214,211,209,206,204,201,198,195,192,190,186,183,180,177,174,171,167,164,160,157,153,150,146,143,139,135,131,128,124,120,116,112,108,104,100,96,91,87,83,79,75,70,66,62,57,53,49,44,40,35,31,27,22,18,13,9,4,0,4,9,13,18,22,27,31,35,40,44,49,53,57,62,66,70,75,79,83,87,91,96,100,104,108,112,116,120,124,127,131,135,139,143,146,150,153,157,160,164,167,171,174,177,180,183,186,190,192,195,198,201,204,206,209,211,214,216,219,221,223,225,227,229,231,233,235,236,238,240,241,243,244,245,246,247,248,249,250,251,252,253,253,254,254,254,255,255,255,255,255,255,255,254,254,254,253,253,252,251,250,249,248,247,246,245,244,243,241,240,238,236,235,233,231,229,227,225,223,221,219,216,214,211,209,206,204,201,198,195,192,190,186,183,180,177,174,171,167,164,160,157,153,150,146,143,139,135,131,128,124,120,116,112,108,104,100,96,91,87,83,79,75,70,66,62,57,53,49,44,40,35,31,27,22,18,13,9,4,0}; void main(void) { unsigned char i=0,j=0,k=0; DDRA=0x00; DDRB=0x13; DDRC=0x3F; DDRD=0x10; TCCR0=0x69; TCCR1A=0x81; TCCR1B=0x09; TCCR2=0x69; TCCR3A=0x81; TCCR3B=0x09; OCR0=0x00; OCR1A=0x00; OCR1B=0x00; OCR2=0x00; OCR3AH=0x00; OCR3AL=0x00; OCR3BH=0x00; OCR3BL=0x00; while (1) { for (i=0;i<spc;i++) { j=i+8; k=i+16; if(i<12) { Phase1L=0; Phase1H=1; } else { Phase1H=0; Phase1L=1; } if((j>11)&&(j<24)) { Phase2H=0; Phase2L=1; } else { Phase2L=0; Phase2H=1; } if((k>23)&&(k<36)) { Phase3L=0; Phase3H=1; } else { Phase3H=0; Phase3L=1; } OCR0=PWMCodes[(i+1)*(360/spc)]; // Output Phase#1 (OCR0) OCR3AL=PWMCodes[(j+1)*(360/spc)]; // Output Phase#2 (OCR3A) OCR2=PWMCodes[(k+1)*(360/spc)]; // Output Phase#3 (OCR2) delay_us((1000000/(f*spc))-adj); }; }; }
