firstliuxin
Newbie level 2
Recently, I am aksed to install some EDA software for our lab in redhat 9.0 OS.
when i installed cadence IC50033, several problems are encounter.
i have 5 CDs, and 3 of them are base BASE, the other 2 CDS for upgrade.
as below:
BASE_IC_1.2.3 ISR2004_1.2
i copyed them on my hard-disk, and obtain 5 .tar files by using deamon tool.
i compress BASE in base directory, and ISR in upgrade directory.
in my mind, i want to install IC5033 in directory /export/home/cad/cadence/IC5033
first, i boot the SETUP.SH in BASE CDROM_1
but it failed to untar the file, the reason given by the system is that the files are not like tar archives.
My friends gave me a "install" directory. which has been modified. i substituted orginal "instal"l directory during my installation. The base has been installed successfully. i confirmed the configuration is correct .including license and cshrc_cadence.
however, when i lanched the cadence application by typing icfb
The system tell me "bad command"
i also can't find icfb in the tools.lnx86/bin directory.
Another problem is that i didn't know how to upgrade the installed product.
Beside the same "untar" problem, i didn't know the method i can follow to upgrade the installede base to IC5033
i need help
[/b]
as below:
i need help
[/b]
