TheTeacher
Newbie level 1
- Joined
- Nov 6, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 20
Hi guys
I'm trying to send 2 different bytes (one at a time) from the slave to the master; different actions must be taken by the slave depending on which byte is received. I wrote some code to confirm that the master is sending the different bytes and it is indeed. I also confirmed that the slave is receiving the different bytes. The problem arises when I modify the code to include the "if statements" to check which byte was received and take appropriate action; this part of the code just doesn't work. I have LED's on RA0 and RA1 to check the results.
Please help!
Please help!
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 #include<htc.h> #define _XTAL_FREQ 4000000 char UART_Init(const long int baudrate); char UART_TX_Empty(); char UART_Data_Ready(); char UART_Read(); void UART_Read_Text(char *Output, unsigned int length); void UART_Write(char data); void UART_Write_Text(char *text); void main() { int d; PORTA = 0x00; TRISA = 0x00; // Set PORTA as output // Set all pins as digital ANSEL = 0x00; ANSELH = 0x00; // Disable comparators CM1CON0 = 0x00; CM2CON0 = 0x00; CM2CON1 = 0x00; UART_Init(9600); do { if(UART_Data_Ready()) {d = UART_Read();} if (d == 0xAA) {RA0 = 1;} else if (d == 0xFF) {RA0 = 0;} __delay_ms(50); }while(1); } /********** UART.h **************/ char UART_Init(const long int baudrate) { ANSEL = 0x00; unsigned int x; x = (_XTAL_FREQ - baudrate*64)/(baudrate*64); if(x>255) { x = (_XTAL_FREQ - baudrate*16)/(baudrate*16); BRGH = 1; } if(x<256) { SPBRG = x; SYNC = 0; SPEN = 1; TRISB7 = 1; TRISB5 = 1; CREN = 1; TXEN = 1; return 1; } return 0; } char UART_TX_Empty() { return TRMT; } char UART_Data_Ready() { return RCIF; } char UART_Read() { while(!RCIF); return RCREG; } void UART_Read_Text(char *Output, unsigned int length) { int i; for(int i=0;i<length;i++) Output[i] = UART_Read(); } void UART_Write(char data) { while(!TRMT); TXREG = data; } void UART_Write_Text(char *text) { int i; for(i=0;text[i]!='\0';i++) UART_Write(text[i]); }
