rosaage
Newbie level 5
I have a Commodore 1084S-P VDE PSU (seperate board from the rest of the circuit) with some problems. If I connect it to 230V input it starts making a high pitched noise, measuring with a multimeter on the output pins gives me ~17V on pin 3 (C146) and 0V on the 25V and 125V rails. I have a spare working monitor with an Identical PSU, so I confirmed the monitor is working fine.
Since one psu was working I started moving over parts from the working psu to try and locate where the fault was as I was not able to meassure anything seemingly wrong. I have replaced:
Transformer T101, Input coil S102, All electrolytic caps except C146, C116 and C122. All transistors, Output diodes (D141,D142) isolator (IC101) and all red capacitors (Film?)
When I power it at lower voltages (<50V) all 3 outputs appear to charge up to the correct voltages, If I then increase the voltage it starts clicking slowly and the scope shows shorts on the output caps (C144). Increasing above ~200V it stays at 0V and the noise is high pitched.
One thing I find strange is that after letting it sit for some days and coming back to it when I power on the circuit it sounds completly normal untill my test leads touch the output caps, then it starts making the noise. Is the Multimeter load responsible for triggering something?
