paurelian
Junior Member level 3
I am trying to build a weighing system but i face some problems with the noise and the stability of the measured value. I built 3 versions of aprox the same schematics but with different layouts. With the first version I got a 14 bit resolution, but this version had some other problems! I tried then other version, reading more about how to build the layout, but the results weren't as i expected to be. Can anyone help me with some tips regarding how to build this layout in order to achieve a better resolution? For this last version i have separate grounds, analog and digital, separate ground planes, short leads for decupling capacitors, separate supplys, agnd and dgnd are connected in only one point, no digital lines under the chip, no high current lines near the sensitive inputs traces for ad7730, decoupling caps as is specified in the datasheet, but still a 10 bit resolution!!! I shorted internally the inputs of AD7730 and i measured the value ... but i couldn't get a better resolution then 10 bit! Has anyone faced these problems and how had he solved them?
Thank you a lot in advance!
